			Good job, but this is WAY OVERKILL. The Ragg Topp (I assume you'll be using....or 303 for that matter) wipes off easily enough, plus you can control the spray pattern, and there is very little over spray.
 Remember, less is best. Do 3-4 light coats. Let dry about 20-30 minutes between coats. Between coats I re-vacuum the top. While still wet right after spraying, I brush with a high quality, dry, China Brissle brush. Been doing this every other year (I use Ragg Topp) since new in 2006, and my Cocoa top looks brand new.
