I'm just a newbie.... but I would check the bottom of the oil cooler (the o-rings like to leak from what i've read - cheap and easy fix), the oil filler pipe joins just to the right of the throttle plate housing (that leaked on mine - replaced the hose). Also on mine the Oil Level sender unti just behind the oil cooler leaked (replaced that too) If you cant find it, clean the top of the motor with brake cleaner and then watch where oil begins to form over the next little while.
