Old 10-09-2012, 09:16 AM   #2
Bruce Wayne
Bruce Wayne's Avatar
Fuel Trim
Fuel trim refers to adjustments being made dynamically to the base fuel table to get the proper ratio of fuel to air. Short term fuel trim refers to adjustments being made in response to temporary conditions. Long term fuel trim is used to compensate for issues that seem to be present over a much longer period. Fuel trims are expressed in percentages; positive values indicate lean (add fuel) and negative values indicate rich (subtract fuel). Fuel trim banks refer to the cylinder banks in a V style engine. Cylinder #1 is always in bank 1. Fuel trim is generally calculated by using a wide set of data values, including front O2 sensors, intake air temperature/pressure (or the more elegent air mass sensor), engine (coolant) temp, anti-knock sensors, engine load, throttle position (and change in throttle position), and even battery voltage can effect fuel trim. Long term fuel trim generally should not exceed +- 10%.
from here: Interpreting OBDII Data
986 x2 6sp
2x Range Rover Vogue 4.6
2004 MX5 Sport 6speed Strato Blue (wifelet)
2x Range Rover Classic & CSK
Bruce Wayne is offline   Reply With Quote
