Thread: IMS install
Old 10-08-2012, 01:19 PM   #12
JFP in PA
with that said, why Wayne came up with the screw locking method of the IMS ?
am i missing something in his great article?
and if i got JFP on the hook , i whould like to ask another question please.
if the oil pan is removed, will i be able to see the tip of the IMS?
what i'm trying to understand, is if in a case of the IMS going of center, will i be able to re center it thru the oil sump.
I can only speculate that Wayne was trying to extend his "low cost alternative" to the required tooling as well.
If you look up with the sump cover removed, you will not be able to see very much as the sump air oil separators (arrows) and oil pick up are in the way, plus there is no real access to the IMS shaft because the sump is crosswise to the axis of the IMS and crank:
