You need to get the LN Engineering kit which has the cam locks. While technically you don't need to lock the cams as some have done...you risk your motor grenading should you jump a tooth.
So if you have a spare 18K laying around and feel lucky you can go this route. Otherwise for a small cost you can lock your engine and cams down, loosen and or replace your cam chain tensioners and be safe to proceed.
