Welcome aboard,
Rattle at the rear could be a catalyst heat sheild, common issue as its a clam-shell type that come loose.
Ref oil changes, drive onto ramps and jack the front end up and onto axle stands to get level. The sump is flat so the more level, the better.
Good luck and enjoy!
It will all end in tears I tell you.......
