Old 10-06-2012, 09:26 AM   #10
BruceH
BruceH's Avatar
Ok, so my low beams are not working. Like others, the high's work if I pull on the stalk but not the normal way. I tried the trick with the snowflake and turning the ignition switch slightly left but no luck. Everything else works. So do you think it is the ignition switch or should I go the route of contact cleaner on the light switch? Any thoughts before I head to an Audi dealer for the ignition switch?
2001 Boxster S Lapis Blue
iPad Mini Dash Install
DEPO Tail Lights
