Originally Posted by healthservices
does it happen only after you change directions and the first initial brake application in that direction?
mine does this! started after my first DIY brake pad change. everything went back in with ease and no "issues" were encountered, but if I go from Reverse to Drive, the very first time I brake (hard or soft, doesn't matter), it makes a noticeable "click" as if the pads are seating against the rotor or something. Any time after that there's no noise.
What causes this? I've been too lazy to check myself. My brake functionality doesn't appear to be affected at all. Still stops on a dime.
