Old 10-04-2012, 08:14 AM   #15
Homeboy981
Homeboy981
Homeboy981's Avatar
@Meir,
One other thing is that the linkage DOES HAVE AN ADJUSTMENT (once OVER the threads) of about 2" of adjustment to the cable length using the threaded end piece. It has a lock nut - which I hit with Blue Loctite too! I DID NOT have to shave bits off the Shifter Cable, just hit with a little WD!
My shifter, with the TS Short Shift Kit AND LINKAGE is TIGHT! No Play in ANY of it. Doubtful that could EVER BE SAID about the Factory plastic. Sounds like you know that. Got pic of YOUR DESIGN?
