Old 10-03-2012, 01:12 PM   #12
sgt brad
02 box s
do not use this product.
the small Allen screws that supposed to attach it to the cable, are a joke.
the inner diameter of the part, is not even close to the size of the cable.
in my case the end of the cable was plastic, so adding the part ruin the thread.
it is almost impossible to adjust after installed.
i'm replacing my transmission cables this week, putting back the plastic part that was perfectly good when removed. ill replace it in 10 years if needed.
that was one of the most stupid things i did on my car, "while i was in there" doing the short shiftier.
homeboy, do you have it installed in your car?
MEIR,
before you throw those away would you mind sending them to me? i'll cover shipping, etc. i'd like to look at them and see what can be done to make them actually work. no wonky allen screws. is the boxster shifter cable actually cable or is it flexible rod? thanks.
brad
sgt brad is offline   Reply With Quote
