Originally Posted by Meir
WOW!
First time I hear about that.
Any chance you can post a pic?
I have a small amount of water coming in on the passenger side. Since both drains are clear ( the two in the foam that are very visible in service mode), I was assuming the top is leaking.
I just got back from the car ( after reading your post ) and I cannot find the extra two holes you are talking about.
Any help will be apriceated.
I'm a luddite when it comes to posting pictures but heres a better explanation. With the top in the service position, locate that little piece between the door and the clamshell. On the side that faces towards the rear of the car, feel around and you will find a small drain, it doesn't face down, it faces towards the body.
