Old 10-02-2012, 02:32 PM   #2
brian325is
I assume you read this portion
Check the finger spring tension by pulling its top edge (white arrow in Photo #3) away from the frame and seeing how strongly it returns. In its normal, originally installed, position the spring has a slight curve towards the front of the car. To increase the tension that the finger spring provides, unscrew the two T20 Torx screws and reverse the position of the finger spring by turning it so that the face that was hidden from view is now facing outwards (i.e., towards the front of the car). The increased tension that the finger spring now provides will help to pull the plastic rib edge of the convertible top material properly into the guide channel in the B‑Pillar. If the finger spring is sharply bent or is broken (less than 5" long), it must be replaced. The finger spring (also called a “leaf spring” or “tension spring”) is part # 986 561 749 00, two needed, and costs about $4.25 each as of this writing.
brian325is is offline   Reply With Quote
