My drivers window has also had this issue after I replaced the regulator. I think it is a alignment problem. Since the window is supposed to raise and drop slightly when closing to clear the lip on the top. If it encounters any resistance, it lowers itself. My regulator just failed again, so I'm going to work on the adjustments better this time and see if it resolves it.
