Old 10-01-2012, 10:33 AM   #11
ProjectM96
Originally Posted by 2000boxster986 View Post
Received a left and right pipes from Top-Speed with no issues. Overall quality appears to be good. However like others mine did not fit as well as I was hoping. I had to do some mods. Some of the proper fitment was hampered by the exhaust modes already done to the car before I bought it. I think it's called a Pedro exhaust mod etc... The Pedro mod has the 1" pipes welded to the U tubes and not the muffler inlet. So, they were unmovable, otherwise I might have been able to tilt the U tubes down for a better fit with the hardware received in the pipe kit.
I wound up using 1 3/4" ID x 2" OD reducers and 2" stainless flexible muffler pipe to get everything to work and to assure nothing was overstressed. I don't particularly like muffler clamps and bendable pipe for exhaust mods but check out the pics below. It's a solid fit and there are no leaks. I'm running stock manifolds with pre-cats.
I don't have the car off the rack as yet but did start it up and it sounds good.
I had the same problem with fitment on my stock muffler. The U-pipe did not connect with the TS pipes. I used all the strength I had to force it in place. I had to loosen the catback exhaust as well to move it back an inch. The problem I have now is an exhaust leak. The TS mid pipe end diameters were much smaller than the factory OEM U-pipe. Not even the clamps are enough to close the gap.
00 2.7 5SPD MT
ProjectM96 is offline   Reply With Quote
