Old 10-01-2012, 07:27 AM   #15
Mark_T
You might get the wheel on faster if you use the alignment post from your tool kit. A good impact gun would shave some time as you wouldn't have to break the bolts loose with a breaker bar first. Also, as you are making a DIY vid, maybe you should include torquing the lug bolts to the correct spec (96 ft-lbs) when re-installing the wheel.
Not being critical, just making what I hope are helpful suggestions.
'99 black 986
