Correct. An air/water intercooler doesn't require direct air flow over the intercooler itself. The cooling happens remotely via a front mount heat exchanger... or in our case, we will be using the factory third radiator as a heat exchanger. Think of it as a mini cooling system, where the intercooler is the engine, and we use an electric water pump to circulate water.
