Old 09-28-2012, 11:48 AM   #14
tranceatlantic
Looking at the manual for SMT6 they say they call the manifold pressure sensor AMP to avoid confusion with their timing maps. So an AMP sensor is a MAP sensor. The boxster has a MAP sensor right? So I just need to wire the SMT6 to MAP input on the ECU. That would be pin 17 I think (labelled as hot film mass air flow sensor).
I tried to install the EGT last night. As I drilled into the exhaust manifold by drill bit melted. That's some tough stuff they make those manifolds from!
tranceatlantic is offline   Reply With Quote
