Old 09-27-2012, 06:47 PM   #12
mistermac99
mistermac99's Avatar
Originally Posted by smshirk View Post
I probably have some that will fit if you can determine what the offset of your wheels are and the thickness of spacers I'll let you have them cheap as I have several sets laying around of both types, in that the thicker ones, 17mm and up have studs and nuts while thin ones require longer bolts
When I had the wheels off a couple weeks ago, I found the front had no spacer and the rear spacer was about 1/4", or 7mm.
H.R. Springs told me that the spacers this thin don't have the lip to hold the wheel on. I think I found them on one other site, but the guy at HR said that lot's of guys buy the thin ones with no lip for the Porsche, without any problems or issues.
1999 Boxster - Arctic Silver Metallic
***As You Think, So Shall You Become***
mistermac99 is offline   Reply With Quote
