Old 09-27-2012, 10:23 AM   #2
rene525d
Would a stop leak be ideal in this case, or is it always better to change and worn seals if possible? Am i undderstanding correctly that if the dye is only visible on the back right near the wheel well, it is most likely a compressor seal issue? I want to rule out the evaporator, as this is such a headache to replace.
rene525d is offline   Reply With Quote
