Here are a couple pictures before and after install.  Hard to see much but figured I'd share since there is so much back and forth on what works.  To install I only removed the 3 nuts on the flange, 2 nuts sliding coupler and 2 nuts on the hanger off the muffler.  Repeat the same on each side of the car.  I did not remove the muffler or anything else.  I did remove the wheel for easier access to the flange nuts.
Stock
Stock
Top Speed
Top Speed
