Thread: Dyno results!!
Old 09-26-2012, 06:58 AM   #13
Topless
Track rat
Topless's Avatar
Originally Posted by shadrach74 View Post
Are you guessing or have you seen data to support this? 18:1 is not really that lean in terms of efficiency ratios. I run a large displacement flat four with a fuel and ignition system far less sophisticated than those in our Porsches at efficiency ratios approaching that level. Some of the new direct injection engines run at 60:1 or more under certain conditions.
Ummm, not if it's running gasoline. 18:1 is way to lean to be safe for full power applications and would not be making good hp numbers. I suspect the exhaust sensor was fouled. Ultra lean burn on direct injection motors is useful at idle or cruising down hill, not making max power on a dyno.
http://en.wikipedia.org/wiki/Gasoline_direct_injection
