Old 09-25-2012, 04:22 PM   #1
Dave928
Location: Seattle - It's not Hell, but you can see it from here!
the throttle plate in the throttle body is controlled by a small electric motor. when you do the procedure above, the ECU tells the throttle plate motor to run open and closed so that it can learn how far it travelled with a given input. this is your "throttle body basic settings".
with a durametric or factory scan tool, there should be a command to force it to do this.
dave
2001 Porsche Boxster S
1988 Porsche 928 S4
Dave928 is offline   Reply With Quote
