Has anyone changed their taillight bulbs? If not, you should at least look at them. Reach inside the trunk and unscrew the plastic nuts that hold the trunk felt panel and remove it. Then push down on the tab that holds the bulb assembly (brake, turn back-up and parking) in. Pull it out and look just how cheap that set-up is.
My 5 year old could do a better job at engineering that assembly!!:troll:
