you'll also want an aftermarket airbox (the 986 air box will be too restrictive and would have to have the maf housing sawn-off); folks are using modified cayman/987 air boxes or you can also look at a bmc unit (CDA or DAI); the k&n universal unit is too small at 70mm.
if you have money to burn perhaps look at the ipd/softronic plenums that can take an 85mm gt3 throttle body.
from what i understand, the aftermarket flashes won't let you delete your sai without a cel; you need a row base flash for that. i.e., get a row base flash, then push a tuned flash onto that.
