Old 09-23-2012, 08:09 PM   #11
Spinnaker
Spinnaker's Avatar
Take off the gas cap and listen at the gas filler tube while someone else turns on the ignition. Do not start the car. If the fuel pump is working, you should hear a whirring noise at the fuel filler neck.
Since the pump works with manual power to it, and you have changed the pump relay, my next guess would be the ignition switch.
