Unless you are trying to make some change to the handling, there's little reason to not use the factory recommended pressures. 30 is not too low at all, and 6 more pounds won't help that much if you nail a big pothole. Also, your 17's are not particularly low profile tires.
PS I have been playing with pressures, and am underwhelmed with the results. The factory pressures gave me good tire wear, so I went back to that.
