Old 09-21-2012, 08:16 PM   #19
papasmurf
Like some others mentioned,
the tape did not work for me. It would not stick to the canvas at all. I used a double sided banner tape that sign shops use to hem the edges of vinyl banners. It is very stick and worked alot better than the recommended tape. The install is not easy or particularly enjoyable but it definately can be done and the money saved can be quite a bit. The only thing I would warn you of is to make sure you get the straps that pull the top inside the side window frame pieces attached properly. The ones on the top I got were somewhat different than the OEM top and I did not get them installed properly and have to make some adjustments to the top to get it to retract properly.
papasmurf is offline   Reply With Quote
