I have had the same problem and I think the solution is the connector on the car as pictured above. I took the wheel well out to access behind and found the connector was not lining up with the connector on the headlight assembly. Pushing down and in a bit while installing the headlight assembly I could feel it snap in and it worked once again. I have had some problems with the assembly coming loose as the pressure bar used to keep the assembly in place was not doing ot's job. I have another post about this near the beginning of this forum.
