Old 09-20-2012, 07:11 PM   #1
dpaisley325
Originally Posted by jrblackbox View Post
Fixed!
The headlight connector on the tray was loose due to the plastic bracket that holds it in place. Had to go thru the fender well. Inserted the headlight then attached the connector to the connector on the headlight!
Thanks for the info. My front headlight assembly keeps coming loose and the lights go out. I have Litronics and the main electrical connector was not seating correctly. I went through the wheel well and pushed the connector down a bit and shoved in the light assembly. It works right now, though I think there is something wrong with the lever that pulls in the light assembly. Question: Can you replace Litronic assembly with the cheaper regular light assembly? The Litronic has two electrical connectors and the cheaper one has only one.
dpaisley325 is offline   Reply With Quote
