Originally Posted by jb92563
Smoke looks bluish so its probably excess oil going through the engine.
Thanks Ray but I need some out of the box thinking on this one. Yes it is oil
Have you checked the plugs?
Yes they are all oil fouled
If one cylinder is darker then it might be a ring or valve problem.
nope
If all are equally colored then its probably some excess oil getting into the induction system somehow.
coming in thru the AOS
Overfilled oil could also be suspect especially if you did any oil change or top ups right before it started.
Acts just like that but the oil is not over filled.
