Thread: Jacking
Old 09-19-2012, 01:27 PM   #14
Deserion
Multi-Boxer Driver
Deserion's Avatar
Originally Posted by trimer View Post
Does anyone have a holy shi& dont do that if you jack up each corner one at a time. I need to fit a jack stand probably at its lowest point of say 13 inches or so under each corner. Is it ok to go right front driver, left front passenger then right rear driver, so on...
Or is there a middle of the car jack point say somewhere under the driver door and one on the passenger side under that door.
Forgive my ignorance...but I just want to be sure not to mess it up. I am sure I can look at the manual but if someone has a great solution that is easier, etc then I am all for it.
Using the rear point behind the door (in front of the rear tire) will lift the entire side of the car. It should give enough space to put both stands under for that height (which is about how I had mine set yesterday). Though I am cautious, I haven't had any issues lifting the entire car off of the ground this way.
-Chris
2004 Porsche 911 C4S Cab
1991 Porsche 911 C2 Targa 3.6
2017 Subaru Outback 3.6R
