Old 09-19-2012, 08:37 AM   #6
MN 986
MN 986's Avatar
I can confirm that when my window acted exactly the same way a while back, I replaced the part Maurice references above and the problem was solved. It was not too dificult to replace (took maybe an hour and a half ), but you will need a special wrench to remove the assembly. I think it was called a triple square wrench (?), but was available at the local auto parts store.
Good luck!!
MN 986 is online now   Reply With Quote
