I woud imagine the switch is just one switch telling the windows to partially roll down when the top is unlatched. So if only one window is doing that, there may be a problem with the overhead switch, but there would also be a problem with the passenger window. If you are permanently leaving the hardtop on, then you may get by with just fixing the overhead switch.
