Old 09-18-2012, 06:03 PM   #1
Mrmaddbrad
Window Tilt Function Problems.
So lets see here. When you open the door on a boxster, and most newer convertible cars for that matter, the window drops about a quarter to a half an inch. When closed, the window moves back up and seals against the weather trim.
On my car, the passenger side seems to work flawlessly. However; on the driver's side, when I open the door, it drops down, but as soon as I let go of the handle (Both inside or out), the window pops back up. This means if I'm not paying attention, the window slaps into the convertible top, scaring me, and forcing me to hold the handle as i close it.
What is wrong?? I assume there is a microswitch of some sort? or maybe its a function built into the window regulator or door lock assembly.
I'm sure some one else has run into this problem. Help please
Thanks!
~Brad
Mrmaddbrad is offline   Reply With Quote
