Originally Posted by MaxQ
Just a couple observations: While these lights look very nice, the quality is quite not on par with OEM. The housing is very flexible and the top of the inner light housing must have rubbed on the lens during shipping leaving a small scratch on the upper part of each lens. Not really a big deal. also If you look closely you can see the internal wiring through the gaps in the housing.
MaxQ:
My lights encountered the same thing being rubbed, what I found was when I turned to lock the light in, it pushes up the projector light into the upper part of the lens.
When I locked the light in, the force required over the OEM was much harder to lock in.
While these light are a cheaper version of the OEM they do add a modern look to the car at a economical price.
I have the DEPO rear lights that have bulb's for turn signals and reverse lights with LED's for running and brake lights. With bulbs being in the rear for turn signals it didn't require a LED flasher.
I have the 3rd LED brake light due to arrive this week with a load resistor.
