Old 09-17-2012, 09:53 AM   #158
politby
politby's Avatar
Originally Posted by SoK View Post
Is it safe to say you could have installed that particular JVC doube din unit without the connects2 kit? Would the bezel that comes with it from JVC have worked?
Any modifications needed to the JVC cage to work with the dash?
The JVC bezel is not tall enough - it would leave a gap between itself and the cupholder, so the Connects2 bezel was definitely needed. As was the wiring harness to connect the head unit and replacement amp to the factory wiring.
The hole in the dash is taller than a standard double DIN so an asymmetrical bezel is a must.
The JVC cage fit as it was, I just needed to fix it to the Porsche plastic frame using a couple of screws..
politby is offline   Reply With Quote
