Originally Posted by RandallNeighbour
From where do I bleed the clutch? That's a new one for me...
Hello Randall.
Here is one of the link I used.
Pelican Technical Article: Boxster Clutch Hydraulics Overhaul (Boxster Master Cylinder & Boxster Slave Cylinder Replacement) - 986 / 987
Don't expect to be able to see the figure 4. I suppose you might be able to see it like in the picture if you removed a bunch of stuff including the bumper. However, I was on my back between the center line of the car and the driver side rear wheel so my POV was a bit different.
Rest assured that the valve is opening/pointing towards the driver side rear tire and it is appx. in line with the center of the rear wheels, (a bit rear?), and high up.
The valve is covered with a plastic cover that comes fully off, (not like the valve covers for the braks), so be careful.
Let me know if you have trouble finding it. I will post some pictures.
