The Depo units must have some resistance built in, as they work fine with any issues. The side bulbs are an odd issue , as they could have just simply drilled a hole in the inside lateral housing and the mini bulb would fit thru. I may do this as a winter project.
Otherwise,My biggest gripe was the depo lights wires that plug into the oem wiring harness were too short to reach, and after several attempts to get them to fit, I cut the wiring, and soldered on some extension wire. Also, there is no room for the left rear fog light, although I never used it anyways.
