Thread: Brembo brakes
Old 09-13-2012, 02:30 AM   #2
simonbutler74
Originally Posted by Scotterboyd View Post
I have a 98 Boxster and want to put the S type Brembo brakes from a 2001 on it. Will they swap out ok? Or should I paint mine red and forget about it. I found them used for cheap and wonder if they will work.
Thanks in advance,
Scott
Pretty much the same brake mounts for those model but you, you will need to do some fabrication with your rear but don’t worry its quite minor unlike the models today where in if you want to do an upgrade you need to replace it with the performance version of that part like brembo brakes. Much expensive since you cannot borrow parts from a different year model.
simonbutler74 is offline   Reply With Quote
