Originally Posted by nicecar
lower control arms rattles over cobblestone driveway , cracks etc... when coasting make sure to do the right and left together. I did one and just did the other a year later but it was still rattiling after i did one side, dealer 389 for the part pelican 207. 20 minute install per side. find a good indy or p.m. me and ill you up here in jax. so you too can save a ton
Would you mind sending a link with the exact part you needed?
I'm seeing this number 996-341-053-17-M80 for the lower rear left/right control arm
and a few other parts labeled control arm links with different part numbers on Pelican.
