Old 09-09-2012, 05:09 AM   #152
politby
politby's Avatar
Okay, the JVC KW-AV60BT is finally in place:
The Connects2 kit was not 100% useful, I was able to use the wiring adapter harness and the bezel but not the cage as the fit was not good and it came with no instructions.
Because the bezel is designed for the Connects2 cage, I had to improvise a bit to make it fit the JVC cage. It's not perfect but good enough.
The Porsche logo is a brake caliper decal. A little on the large side but it matches the silver details in the cabin perfectly.
The cubby above the climate cotntrol will be turned into an iPhone dock. Still trying to figure out how to get the JVC to work properly with the iPhone, it refuses to display ani kind of image. I have a parking brake bypass on order; hopefully that will sort it.
politby is offline   Reply With Quote
