Originally Posted by PCC010
Hot news and it is hot!
You guys with smoked lights don't use your fog lights!
I understand that the heat from the bulb may be melting the matte black coating.
Jeremy from xtreme is on to it and it may be LED foglight bulbs may be the. Way to go.
I know one of my bulbs is set low and I have a fine crack. Easily fixed I would add with a long paint brush and matte nail varnish.
Better to be safe than sorry.
Sure Jeremy will sort it out.
Chrome lights no worrieS - lucky you!
PCC010:
Are you referring to H7 HID fog light bulb or the standard stock H7 bulb..?
I'm running the standard stock H7 bulb.
There is a rating on the side of the light that spec's what bulbs are required and max wattage.
I don't normally run the fog lights, but would like to know..
Keep us informed.
Tony
