Old 09-07-2012, 03:21 PM   #14
tony_fury
2001 Arctic Silver 2.7
tony_fury's Avatar
Originally Posted by thom4782 View Post
I have a similar two beep problem. Using a Porsche diagnostic computer, I got codes 61 and 47. Does anybody know what those are?
As a first step, I am going to replace the central locking switch and see if that fixes the problem. If not, I'll need to dig deeper. The diagnostics didn't really point more directly where the problem might lie.
Anybody have any other thoughts on this.
thom4782:
If you replaced your stereo with an aftermarket. Make sure you DO NOT ground the wire on the side of where the factory stereo was.
This wire is normally open, when the factory radio is removed it then makes contact to ground. Which in turn will cause you alarm system to beep once when armed, and twice when unarmed with the remote.
When replacing the factory stereo out, ensure that wire is just taped up and not connected any longer.
Hope this helps
T
RMS, IMS, 87.5K
