Originally Posted by Cater
I'd strongly advise against the K&N air filter. The oils off the filter messes up the mass airflow sensor. That's why the filters are cheaper for the boxster then most any other car.
The only reason the air flow sensor get's messed up is from overoiling the filter. You need to use the spray oil sparingly, then let it drain on a paper towel overnight and all will be well. I have been running K&N filters for years without ANY problems with my maf sensor.
