Can AOS leak oil? oh Yes...!
Hi Sasha,
A couple of months ago I discovered an oil leak between the head and the block, that looked like the part of the head gasket that covers the cam chains was failing, also I noticed as well a light seeping from the main seal...
Upon closer inspection, later I noticed that the top of the engine was also covered with oil around the AOS...
I went ahead, replaced the AOS, cleaned the top and bottom of the engine and about 2,000 miles later I can assure that the leak was from the AOS, not the gasket or the main rear seal, it was a big relief...!
BTW, I paid for the new AOS less than $100 (delivered) from Rector Porsche
