That looks exactly like mine. Do you have a link to the whole image?
If you look at the radio support bracket in my photo, you see that it has a black metal profile at about mid height, one each side, presumably there to support the now-relocated climate control. They will effectively block the insertion of a double DIN radio, so they must go. They will be impossible to remove unless the entire bracket is removed.
Possibly I could get it out if I can pull out the cupholder; the picture you posted a part of may tell me how.
Edit: now that I look closer at your photo I see your car has those black metal supports too. You must have removed them, otherwise you could not have fitted your unit.
