Old 09-05-2012, 05:32 AM   #145
politby
politby's Avatar
Originally Posted by tony_fury View Post
You model dash is different from mine.
The air vents came out with my horseshoe. Also my cup holders were different from yours as well.
You have as much access as you can possibly get, you should be able to run your power wire to the fuse box with that access.
They changed the design from MY03, I believe.
The reason I want to remove the entire frame is that I want to do the cutting for the new radio cage out of the car, and also removing the factory radio support bracket (which in my car is U shaped and seems to be joined to the vent assembly with clips) will be easier.
politby is offline   Reply With Quote
