Old 09-04-2012, 10:40 PM   #1
tony_fury
2001 Arctic Silver 2.7
tony_fury's Avatar
Originally Posted by 97 Boxster View Post
Come on, NO HELP on this one? I need to know if there is a reset code or if I need to now replace the regulator. Somebody PLEASE give me some advice.
Question:
Does the inside door handle trigger the window to drop?
With the door panel off did you do any testing of the both door handles?
My passenger outside door handle intermittently doesn't drop the window.
When I tested the inside door handle it drops every time. This leads me to believe the outside door switch is the one at fault.
I haven't pulled the trigger to replace it yet.
These cars are full of micro switches attached to handles, while the handle keeps working the switch wears out.
Window reset procedure
The window reset procedure just lets the car remember what the last position of the window was. When the window is fully up and the door handle is pulled, the car runs the window down for a time interval that should be enough for the window to clear the top.
If the window still does not clear then it’s a mechanical issue, it's possibly a window regulator.
Could be slop in the cable.
It's my understanding that the regulator develops slack in it over time from use and the cables stretching. When the motor runs it does not move as far as it should.
Taking up the slack in the cable instead of moving the window.
Hope that helps
T
RMS, IMS, 87.5K
