Old 09-04-2012, 05:31 PM   #11
dan.oneufer
dan.oneufer's Avatar
There is only so much you can see without dis-assembly, so aside from overall condition check the CV boots at the wheel if you can. I just looked at mine (which only has 32K miles) and both are torn. Also, lift the carpeting or reach under the seam to see or feel it there is any moisture (coolant) in the trunk.
2003 Boxster S Dark Teal
dan.oneufer is offline   Reply With Quote
