Old 09-04-2012, 04:29 PM   #14
Boxster586
Originally Posted by Jittsl View Post
Im glad you had no issue.
Yours however must be different from mine. Mine have no adjustment at the front. There is a welded flange that that bolts up to the rear of the headers and that's it. Likewise mine have no tacked in nuts.
I have a 2003 base with a 2.7 engine with factory headers and factory primary cats. The flanges are NOT adjustable. I just had to install the end of the test pipes into the muffler first and then twist the pipes so that the holes in the flanges line up.
Sorry you had a tough time with your set up......it sure takes the fun out of modding these great cars when issues like yours come up. I Hope things work out for you in the end because I sure like the way my car sounds after the install.
Best of luck to you.
Boxster586 is offline   Reply With Quote
